76 celica 20r in a 80 pick up
1976 TOYOTA CELICA
LJSTOY
  • 6 POSTS
what does the single wire terminal on the distributor go to?
80 model truck has two wires coming from distributor to the ignitor. From what I can tell the celica doesn't have an ignitor? What is an ignitor anyway?
Oct 1, 2007 at 2:37 PM
[quote:d2b8b76ffb="ljstoy"]what does the single wire terminal on the distributor go to?
80 model truck has two wires coming from distributor to the ignitor. From what I can tell the celica doesn't have an ignitor? What is an ignitor anyway?[/quote:d2b8b76ffb]
I believe that wire goes to the ignition coil check terminal
It better have an ignitor if its not a contact point distributor. The ignitor tells the coil to fire the plugs its purpose is the same as the contact point its job is to switch the primary winding on and off to create the power surge to the secondary circuit to fire the plugs. Soild state device no wear and tear- instead of the contact point that you need to adjust the cam angle/dwell once in a while due to wear.
Oct 1, 2007 at 10:08 PM
LJSTOY
  • 6 POSTS
I'm still confused or making this bigger than what it is. The truck (80 yota p/u with 20r) had a box ontop of the coil that said ignitor. It had two wires coming out and went to the distributor with a two prong clip. The new motor and distributor (76 celica 20r) has a terminal for a wire (no clip or anything) but i don't know where (on the coil or what) to attach the wire. Which one is the "igniton coil check terminal" on the coil? The inside of both distributors are completely different looking. How do I know that it doesn't have contact points? If it does, then where does the wire go. I just want to make sure I put it in the correc spot before screwing something up. I haven't even tried to start the motor yet. Not sure if it even runs. just crossing my fingers.
If its a contact distriibutor it will only have one wire on it and that one goes to the coil negative.
Disregard that wire -hook everything up and attempt to look for spark while cranking it over-if your getting fire it up.
BTW what color is this wire?
Oct 2, 2007 at 5:34 AM
