2003 Toyota Celica
CALI24769
Engine problem
2003 Toyota Celica Front Wheel Drive Manual 50,000 miles
i was going thru a water puddle, and my car is lowered and it has a AEM cold Air Intake and it just stalled out when i went through the water.. and i tried to turn it back on and it wont turn on we tried to turn it on 20min later and still wont turn on what do you guys think happened?and how can i fix the problem?
Nov 30, 2007 at 12:11 PM
  • 31,937 POSTS
Hi there,
I will need a little more detail. Will it crank over? If it is cranking is there any spark? How much water was splashed up into the engine bay? Has there been water in the air filter? Is there water in the air inlet hose before the manifold?
A few things to check first.
Mark (mhpautos)
Nov 30, 2007 at 12:24 PM
CALI24769
yeah there is a spark and it is cranking do you think it willl be fine?? and no idk if thre water got soaked up by the air filter
Nov 30, 2007 at 12:45 PM
  • 31,937 POSTS
Hi there,
As long as there was no large ingestion of water into the engine, things should be fine. Pull the spark plugs and clean, if they are black and sooty or wet with fuel, this will make it hard to start.
See how you get on.
Mark. (mhpautos)
Nov 30, 2007 at 1:59 PM
