2002 Toyota Celica window
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
COWBOYUPCMR
ive ran out of solutions for my wifes passenger side window. The driver side works good as well as the power locks but i cant get the passenger side up. Ive tested the motor and that is good. I also bought a new center control switch to see if that was the problem and it wasnt. Im thinking it might be something with the wiring but iI dont even know where to start with that. Any Ideas on what to do next?
May 21, 2008 at 9:47 AM
  • 31,937 POSTS
Hi there,
start at the beginning again. check that you have power at the motor plug for up & down if not go check switch & power supply. This is a reverse polarity system so the earth Will switch as dose the power so make sure that you have a earth on the plug on both up & down. Start there.
Mark (mhpautos)
May 21, 2008 at 10:40 AM
