2002 Toyota Celica flooded
2002 TOYOTA CELICA
85,000 MILES • 4 CYL • 2WD • MANUAL
MARWANDAHLAN
Hi, my car got flooded, I got it towed home, and I did not have time to work on it for weeks
When I got time to work on it, they key won’t come out, and Engine won’t turn, no water in the oil, and car won’t turn at all, I chine the battery, plugs, oil, air filters, but nothing
Can you help please?
Mar 18, 2010 at 5:54 PM
KHLOW2008
  • 41,814 POSTS
Hi marwandahlan,
After replacement of the battery, are you able to remove the key? Did you try removing it with the battery disconnected?
Check the starter motor for the non cranking. The water and not working on it after a lapse of weeks can result in the starter seizing.
Mar 19, 2010 at 4:34 AM
