2001 Toyota Celica Speedometer and Odometer are not working
41,000 MILES • 4 CYL • 2WD • AUTOMATIC
2001CELICA
The speedometer and Odometer are not working. I was told that it would most likely be the speed sensor. If it's the speed sensor, then why is the odometer not working also. Shouldn't that affect the speedometer only?
Jun 11, 2008 at 5:50 AM
KHLOW2008
  • 41,812 POSTS
Hi 2001Celica,
Both the odometer and speedometer operates with signals from the speed sensor so if one stops, the other stops, unless it is the meter that is faulty, then maybe one would work without the other.
Jun 12, 2008 at 4:04 AM
VANNY76
My celica has similar issues, and it always says that I am empty on gas, did you ever find a solution to your problem?
Aug 28, 2009 at 2:30 AM
