2001 Toyota Celica radiator
2001 TOYOTA CELICA
MARINEFORC
Engine Cooling problem
2001 Toyota Celica 4 cyl Front Wheel Drive Manual
what does it mean when the radiator fluid keeps boiling out of the reservoir
Feb 8, 2010 at 10:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
few different things may cause this issue..bad radiator cap or partially clogged radiator are easiest fixed. suggest having the cooling system flushed and also ensure that cooling system is bled of air properly. check drive belts also to ensure it is operating water pump.
Feb 8, 2010 at 10:22 AM
