2001 Toyota Celica AC receiver/drier
DCRUZ523
Air Conditioning problem
2001 Toyota Celica 4 cyl Front Wheel Drive Automatic
Is it necessary to replace the drier/desiccant bag when opening and servicing the AC system, or will a deep vacuum be sufficient?
Mar 26, 2010 at 11:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you will want to replace the dryer when doing a/c repairs yes..if you was replacing the compressor than the warranty most likely states that it will be void if you do not replace the dryer also..
Mar 26, 2010 at 11:42 AM
