2000 Toyota Celica oil loss
2000 TOYOTA CELICA
145,808 MILES • 4 CYL • FWD • AUTOMATIC
AUBURN75
my car is losing oil some how.it is not burning oil but i think it is leaking somewhere.but i cannot find the leak,ive parked on my car port and there is no sigh of oil on the ground,the loss is about 2-3 quarts a weak,i have changed the valve cover gasket,oil pan gasket,and will soon replace the oil pump gasket.what else could i replace to stop the leak
Sep 9, 2009 at 3:45 AM
If you're not burning it -its leaking somewhere externally -check the front and rear seals-inspect the oil if its milky-That 2-3qts a week has to go somewhere-
Sep 9, 2009 at 5:53 AM
