2000 Toyota Celica Injector Pulse
TOM36
  • 2000 TOYOTA CELICA
  • 4 CYL
  • MANUAL
  • 70,000 MILES
Stuck on this car have fuel to the rail plenty of spark and no injector pulse? Checked all fuses and all relays all work just fine if I manually ground each injector. I am stuck and sure its either in the ecm or a broken wire somewhere between the ecm and the injectors any help or suggestions would be great. Thanks
Thursday, March 26th, 2009 AT 7:57 PM
MMPRINCE4000
  • 8,548 POSTS
I would check the injector harness for missing insulation, the injectors use a common ground, so I would suspect the wiring, before replacing the ECM.
Friday, March 27th, 2009 AT 7:49 AM
TOM36
How can I check the ecm toyota dealership is far away and pricey any other way?
Saturday, March 28th, 2009 AT 12:08 PM
MMPRINCE4000
  • 8,548 POSTS
I would probably try a junkyard for a used ECM. Plug it in and see if injectors work.
If the fuses/fuseable links/relays are all OK, then the injector drivers in the ECM are burned out.
Saturday, March 28th, 2009 AT 10:04 PM
