ADDING COOLANT
ROGERDHALL
I have a coolant leak but I can't see where it is coming from can you please help me? I am disabled but want to fix it myself.
Thank you Bud,
Jan 9, 2010 at 4:14 AM
HECTOR.ALVAREZ
if you drained the radiator it's a long process. you need to remove all the dress up around the engine, unbolt the reservoir and remove the air filter cover until you can remove the bolts holding down the hose that goes under there. you should be able to put the reservoir on the hood latch, remove the bleeding valve on the reservoir. it's a long annoying process. from there you just fill it up to the full line and turn the car on, filling it up while the engine takes the coolant down-
Mar 29, 2010 at 8:58 AM
  • 55,822 POSTS
Sure it sounds like you have a blown head gasket or the water pump is leaking which can come and go. Here are two guides to help you see what's going on.
https://youtu.be/GSE9skKnOgY
and
https://www.2carpros.com/articles/car-is-leaking-coolant
and
Cheers, Ken
Nov 26, 2017 at 12:52 PM
