2000 Toyota Celica A/C - Heating Problems
122,000 MILES • 4 CYL • FWD • AUTOMATIC
BWKET
I had a new engine put in at a Toyota dealer last year. My wife mentioned that the A/C wasn't cooling right but never said any more. I now drive the car and the temperature is sporattic. It blows cool but not cold. It gets warmer if the car is sitting still. Both fans work correctly. The oddity is that during cool weather, it will blow warm for a while then just blow cold (with no changes made and A/C off.). It will then blow warm again, etc. The clutch is engaging and the engine temp is always normal. Is there something that controls the systems output temp that is gone bad. Was it something from the engine swap left unplugged. It's been too long to take it back to the dealer now. Thanks.
Oct 15, 2008 at 9:22 AM
RACEFAN966
  • 5,029 POSTS
You say the A/C clutch is engaging but is it cycling or staying engaged? If it is engaging and disengaging alot (cycling) the it may just be low on freon.
Oct 15, 2008 at 2:40 PM
BWKET
It engages for a good while. I've had the freon checked and it's ok. I just don't understand how, during cool weather, it blows from hot to cold as it wishes. I didn't think the compressor was even in the picture then.
Oct 15, 2008 at 11:03 PM
RACEFAN966
  • 5,029 POSTS
Have you checked the blend door or blend door motor? When they go bad your heater or A/C won't heat or cool right.
Oct 16, 2008 at 2:08 AM
BWKET
I haven't and don't know what it is. Where is it and what's required to check it? Good chance that may be the problem.
Oct 16, 2008 at 5:06 AM
RACEFAN966
  • 5,029 POSTS
It is probably on the passanger side of the car near the blower motor. Just behind the glove box kind off. Here is what he comon blend door looks like
https://images.2carpros.com/forum/automotive_pictures/249564_379286_2.jpg
Now if there is a pen or object in the heater system and stops the blend door it will stop it from moving so it could be just that simple
Oct 20, 2008 at 11:41 AM
