toyota celica heater doesn't work
54,000 MILES • 6 CYL • 2WD • MANUAL
SOLARSTU
hi my heating doesnt work on my toyota celica 1.8 vvti 2000, the car isnt over heating and the heater just blows cold air . could you help please thanks
Dec 17, 2010 at 9:12 AM
  • 55,865 POSTS
Hey SOLARSTU,
it sounds like you have a if you have a manual system check the heater control cable. Here is a diagram below to show you how the cables work. Also check the level of your coolant the heater is the first thing to stop working when the coolant is low. This guide can helps us as well
https://www.2carpros.com/articles/car-heater-not-working
Please run some tests and get back to us.Please run down this guide and report back.
Jan 18, 2017 at 2:12 AM
STANPACKER
My daughter's 2000 Toyota Celica isn't generating any heat. The blower's working & she had a/c working throughout this summer fine. The Temp gauge on the dash seems to respond to the engine temp ok. What other troubleshooting steps could I take to get to the root cause. There isn't any leakage of anti-freeze on her floorboard.
Jan 18, 2017 at 2:21 AM (Merged)
ZACKMAN
  • 4,202 POSTS
Did you check the coolant level? If level is good, problem may lie in stuck open thermostat.
RADARROB
I had this problem the heater core was plugged solid I had to flush it for an hour... all fixed!@
Jan 18, 2017 at 2:22 AM (Merged)
  • 31,937 POSTS
Hi there,
If the engine temp is lower than normal, replace the thermostat, Check the heater hoses are both about the same temp. If not check the heater tap and the tap controller operation.
Mark (mhpautos)
T_HESS
heater is blowing cold air 90% of the time. temperature gauge is spiking to overheat randomly than back to normal 2sec later.
  • 75,988 POSTS
Try replacing the thermostat and see what happens
T_HESS
already did...
T_HESS
i already did....
  • 31,937 POSTS
have radiator cleaned, bay bed part blocked in the cores restricting circulation, not just a back flush but a full clean by a radiator repairer.
WRENCHTECH
  • 20,758 POSTS
The erratic temp indicates there is air in the system and it needs to be bled out thoroughly. Using a vacuum fill method is the best way to get all the air out.
