1997 Toyota Celica Mirror electrical
1997 TOYOTA CELICA
15,000 MILES • 4 CYL • FWD • AUTOMATIC
LOSTINIOWA
I replaced pass. side powered mirror. spliced the wires rather than removing door panel to access plug in. Initially, mirror worked. Now, neither mirror works. Fuse is good. No power to fuse block where fuse plugs in, but all other fuses in the block are powered and working. All other elecrical accessories working. I have no Idea where to begin to trouble shoot this. Any ideas? Thanks for your consideration.
Jackie
Jan 12, 2008 at 11:54 AM
FISHERMAN
  • 937 POSTS
Hello !! Well.. looks to me like you have a broken (short) wire behind the fuse box.... check and follow the wire from behind the fuse box, here`s the schematic: If to small let me know and i will send it to your email. good Luck!
https://images.2carpros.com/forum/automotive_pictures/576_0_6.jpg
Jan 12, 2008 at 1:56 PM
LOSTINIOWA
This problem is actually w/a 97 Camry. I couldn't figure out how to go back and change it in the listing.
Thanx! Jackie
Jan 13, 2008 at 1:06 AM
FISHERMAN
  • 937 POSTS
Hello Jackie! here`s the correct Camry 97 mirror schematic and i will send it to your mail in full size!: good Luck!
https://images.2carpros.com/forum/automotive_pictures/576_0_7.jpg
Jan 13, 2008 at 8:35 AM
