1995 Toyota Celica Sticking Clutch
1995 TOYOTA CELICA
138,000 MILES • 4 CYL • FWD • MANUAL
BLATANTBELL
The clutch peddle keeps sticking down every now and then, I have to pull over and pull the peddle back up. it goes down then just stays there. My mate has sprayed the peddle spring with WD40 but its not done anything. Can you help???
Thomas
Apr 14, 2008 at 6:32 AM
  • 31,937 POSTS
Hi there,
You may have to remove the pedal and replace the pivot bush, you can check this by un clipping the master Cly rod and unbolt the master Cly and pull back a little so you can feel the pedal, if there is any binding you will have to do the bush, if ok, check the master cyl is working freely and that there are no leaks.
Mark (mhpautos)
Apr 26, 2008 at 8:29 PM
