1995 Toyota Celica Re: Noise when turn steering wheel
1995 TOYOTA CELICA
190,000 MILES • 4 CYL • FWD • MANUAL
KELLY B.
For a little over a year, when it is cold outside (<50 degrees), when I turn my steering wheel I get a rubbing sound. It sounds like it comes from the steering wheel itself. My power steering fluid level is fine. Also, for about a week my belts are starting to squeak when I first start my car and then turn my steering wheel. I changed all my belts about 2 years ago. Do you think my power steering pump needs replacing?
Feb 12, 2008 at 10:10 AM
MASTERTECHTIM
  • 4,750 POSTS
these are seperate problems. first of all the noise in the steering wheel is probably a dry bearing that is probably not cost effective to fix. the squeek when turning is a loose belt, have them rechecked.
Feb 12, 2008 at 10:14 AM
