1995 Toyota Celica ecm failures
1995 TOYOTA CELICA
190,000 MILES • 4 CYL • FWD • MANUAL
DUSTIN SAVAGE
I had the ECM replaced in my celica abut 8 months ago. It seems to have failed again. It is having the same symptoms as before: stops running, wont start at first, then in a few minutes to days it will start again, it is cutting off the fuel. Is there a component that may be spiking the ecm and causing my headaches? I am at wits end with this car and the ecm!
Sep 21, 2009 at 2:34 AM
Block the vane flap wide open in the airflow meter and see what happens
Sep 21, 2009 at 5:30 AM
