1994 Toyota Celica won't shift into gear
DAMONEGIRL
Transmission problem
1994 Toyota Celica 4 cyl Front Wheel Drive Automatic
my car wouldn't shift out of park so i checked the trasission fluid and was low so i added fluid and it still won't go into gear. do you know what the problem is?
Nov 28, 2008 at 6:09 AM
  • 75,988 POSTS
Did you meant won't come out of park
Nov 28, 2008 at 6:15 AM
DAMONEGIRL
yes. it won't shift out of park.
Nov 28, 2008 at 6:59 AM
  • 75,988 POSTS
Check the brake switch if okay-have the shift interlock system checked out-could be the shift lock control solenoid.
Nov 28, 2008 at 7:02 AM
DAMONEGIRL
i had my foot on the break so don't think that's it but when i push the button on the automatic shifter i can hear a clicking noise in the ignition.....
Nov 28, 2008 at 7:15 AM
  • 75,988 POSTS
The shift interlock computer gets it power thru the brake switch-get the system checked out then comeback if more help needed.
Nov 28, 2008 at 7:22 AM
DAMONEGIRL
thank you very much! : )
Nov 28, 2008 at 7:27 AM
