Can you please list all the things that can be wrong with my car if the check engine light is on?
Sunday, March 9th, 2008 AT 9:59 PM
MECHANIC
Hi there,
When the check engine light is on, there is a fault code set for the engine management system, this will cover around 40 different parameters, so it will be a lot simpler to have the code read and report back as each fault code is an individual item at fault.
