1994 Toyota Celica Car hessitation/Burning oil
124,000 MILES • 4 CYL • FWD • MANUAL
7AFECELICA
This is a long story, I will try to keep it as simple as possible for no confusion. :)
My car has been burning oil for quite some time now, quite a bit actually (dependent on my driving,about quart a week). It happens alot as far as I can see visibly (blue smoke), on start up(engine cold) and on like a hill (excessive gas pedal, I have a standard)
I have replaced alot on the car (spark plugs, wires cap rotor, PCV valve, intake, many others feel free to ask, if you think it may be the source of my problem, but i think the problem is internally)
My car has no check engine light, and no stored trouble codes. About every 2-4k miles I have! to replace the spark plugs because cylinder ones spark plug becomes far too fouled, and the engine miss fires. I know the feeling of it miss-firing from past experiences.
But the last time I replaced the spark plugs cylinder #3 was fouled out as well. This was about 1k miles ago. I recently have been driving and anything above like 20MPH with ANY excess in gas pedal pressure (I am 18 but I DO NOT slam the gas i love my car, any thing above like the slightest pressure will cause this) the car will like sputter, hesitate, "knock", jerk, its a weird thing to experience.
This feels nothing like my old spark plug being fouled out and the engine miss-firing. It is like a total loss of power.
I think it may be the piston rings are going in my car, or maybe something like the valve seals??
Thanks to any one who can help out here. Please feel free to ask me any questions
Oct 19, 2009 at 5:52 PM
  • 75,988 POSTS
Blue smoke during cold starts indicates valve stems/seals
Oct 19, 2009 at 7:25 PM
7AFECELICA
[quote:c736713350="rasmataz"]Blue smoke during cold starts indicates valve stems/seals[/quote:c736713350]
What about the hills, well come to think of it it is mainly noticeable when the car is cold. This would also make sense with my new condition right? if like the valves weren't seating properly or were getting stuck the engine would kind of jerk like i was explaining right?
Oct 19, 2009 at 8:22 PM
  • 75,988 POSTS
You're leaking oil in the combustion chamber whether hot or cold condition it will foul the plug/s and will cause a misfire-Blue smoke will show up on initial start ups and demand accelerations.
A tune-up does no good if there's a problem in any cylinder/s. You need to get the upper end fixed-Valve Job
Oct 20, 2009 at 1:26 AM
