1993 Toyota Celica Ignition
14,600 MILES • 4 CYL • FWD • MANUAL
MIKE HEBERT
Cars battery ws low due to non usage. I got a couple of turns, but not enough to start. I disconnected the battery, recharged and now no power to the ignition. Emergency lights work , battery is charged.
Insigts?
Aug 24, 2008 at 4:56 AM
  • 31,937 POSTS
Hi there,
Check the engine & ecu fuses as one may have spiked when the battery was connected, also do a scan just to see if you have any set fault codes in the ECU.
Mark (mhpautos)
Aug 25, 2008 at 6:31 PM
