have just had a new thermostate fitted due to over heating, but i find that when my car gets warmed up my air conditioning fan comes into work instead of my main cooling fan. even with the air con turned off. this started to happen the same day as the new thermostate was fitted but no wiring was touched. a lot of water did blow over the engine the day before due to a badly put on rad cap.
can you help is it any thing to do with a blown fuse? thank you
Feb 23, 2010 at 2:28 AM
