Engine Mechanical problem
1993 Toyota Celica 4 cyl Front Wheel Drive Manual
while doing a compression test on the vehicle the tester hose stripped and only the hose turns but not the fitting inside plug hole any idea to get it out.
thank you
thank you
Mar 18, 2009 at 2:57 PM
