1993 Toyota Celica compression tester stripped
FONGVANG5
Engine Mechanical problem
1993 Toyota Celica 4 cyl Front Wheel Drive Manual
while doing a compression test on the vehicle the tester hose stripped and only the hose turns but not the fitting inside plug hole any idea to get it out.
thank you
Mar 18, 2009 at 2:57 PM
BLACKOP555
  • 10,386 POSTS
use vicegrips or cut it off and use a large easy out to take it out.
Mar 18, 2009 at 3:07 PM
