1993 Toyota Celica clutch
1993 TOYOTA CELICA
185,000 MILES • 4 CYL • FWD • MANUAL
STATO7400R
i recently replaced the stock clutch with a performance one. i put 700 miles on the new clutch with no problem. the other day i started the car and the clutch stayed on the floor. i replaced the slave cylinder gravity bled it as i was instructed and still have the same problem. if you lift the pedal off the floor and press it in it works . but doesnt return on its own. also if you push in the clutch with the car in gear after about 20 seconds it engages.
Jan 24, 2008 at 5:33 AM
Check the clutch master cylinder/adjust the free play and pedal height-bleed the system.
Jan 28, 2008 at 8:23 PM
