Transmission problem
1992 Toyota Celica 4 cyl Front Wheel Drive Manual 125k miles
I recently did some repair work on my girlfriend's aunt's car. i pulled the engine, changed the timing belt, water pump, tensioner, and clutch assembly. i was wondering what i should charge as a "good guy" price. I'm not sure if this is the type of question you usually get but i figured it was worth a try. P.s. everything works perfectly...
Jul 23, 2008 at 5:31 PM
