Just bought car (seized) I opened sunroof, now it won't close. No noise, nothing. Looking for direction to fix
Dec 13, 2007 at 8:49 AM
2CARPRO JACK
✓Experienced Mechanic
Start with the switch. Using a test light verify that it is switching power back and forth to work the motor.If ok, then need to gain access to the motor assembly to verify there (no bad wires), if has power/ground at motor, the motor is bad
Dec 13, 2007 at 11:36 PM
