1992 Toyota Celica Lean Air/Fuel fault code, engine hesitat
POZOBYT
  • 37 POSTS
Engine Performance problem
1992 Toyota Celica 4 cyl Front Wheel Drive Automatic
My check engine light comes on around 55 mph and goes off when I stop, it's throwing a code 25 (lean air/fuel mixture) I just got a full tune up a month ago, I have cleaned the IAC, replaced the TPS, My fuel pump is good. When I accelerate, my car also hesitates, I can push the pedal all the way to the floor, and it takes a second for it to respond, and when it does respond, it still doesn't have the power that it should have. What could be causing this?
Apr 25, 2010 at 6:08 PM
  • 75,988 POSTS
Hi pozobyt, Welcome to 2carpros and TY for the donation
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
Apr 26, 2010 at 7:59 PM
