1992 Toyota Celica engine runs rough between 2000 - 4000 rp
1992 TOYOTA CELICA
265,000 MILES • 4 CYL • FWD • MANUAL
RHOMAN
the engine runs rough between 2000 and 4000 rpm. it runs good under 2000 and over 4000.
looks like it has a new distributor and cap on it. jusedt replace the plugs and wires. i checked the timing and it looks OK.
when you engine gets to about 3000 rpm, the check engine light comes on with a code of 41.
Nov 10, 2008 at 1:54 PM
RHOMAN
the check engine code is 52, 41 was the aribag(fixed that one)
Nov 11, 2008 at 9:22 AM
