1992 Toyota Celica Car Skipping
198,000 MILES • 4 CYL • 2WD • AUTOMATIC
CBUL0131
Plug wires and plugs have been replaced. Compression check shows 220 psi in all four cylinders. Cylinder #4 is not firing even though the plug and wire is. Could this be a bad fuel injector on cylinder #4? Any suggestions on what we could check?
Nov 3, 2008 at 10:25 AM
  • 75,988 POSTS
Try swapping injector and see what happens-
Nov 3, 2008 at 10:33 AM
KYLEATUSA
My Celica just did the same, it was #2. Someone told me to use a mechanics stethoscope ($5-$10) and hold it to each injector. Listen to the good ones first and then check the one you think is bad. If you hear and it is ticking, but like a higher pitch dry tick, you may have a clog in your fuel rail.
Dec 29, 2008 at 8:36 AM
