By car pulsates when I apply the brakes. Is this caused by the rotors?
Apr 9, 2009 at 5:02 AM
BLUELIGHTNIN6
✓Experienced Mechanic
That is the most common culprit. If the rotors have been warped/damaged then it will cause braking vibrations usually felt through the pedal as well as the steering wheel.
