1991 Toyota Celica under normal mileage
1991 TOYOTA CELICA
25,000 MILES • 4 CYL • 2WD • AUTOMATIC
POET2MC
  • 6 POSTS
Im trying to figure out what tuneups would i need to go through to get my mileage back up to where it used to be.
fuel filter? hoses? idk.
Nov 21, 2008 at 2:59 AM
  • 31,937 POSTS
Hi there,
Start with a comp test and if all is OK, check valve clearances, replace spark plugs, leads if they test high resistance, check the dist cap for tracking marks (carbon lines inside) replace fuel & air filters, check ignition timing, replace O2 sensor if it has never been replaced, as a tired old O2 sensor will make the ECU go rich on the mixture, add fuel system cleaner, check all vacuum hoses and do a scan for any set fault codes.
Mark (mhpautos)
Nov 21, 2008 at 3:04 AM
