1991 Toyota Celica Rough Idle
155,000 MILES • 4 CYL • FWD • AUTOMATIC
GORDON B. DALL
This car has a rough idle. If I jump the service electrical connector TE1 to E1 the motor runs great. As soon as I disconnect the jumper it idles rough again. ?
Nov 3, 2008 at 2:28 PM
MMPRINCE4000
  • 8,548 POSTS
When you jump the connectors the IAC goes to the fully closed position, It also removes all computer advance so you can set mechanical timing, so I would take the IAC off and clean it and the TB port. That should help fix the idle.
Also look for any vacuum lines that are suspect, cracked/torn.
NOTE: Do not remove the IAC with ign. on or diagnostic terminals jumped.
Nov 3, 2008 at 11:33 PM
