1991 Toyota Celica hose leak ?
58,000 MILES • 4 CYL • FWD • AUTOMATIC
PLAYINCARS
wonderin' if the rack goes out or a hose, havin problems seeing were the leak is comin from
May 11, 2008 at 6:22 AM
  • 31,937 POSTS
Hi there,
You may have a leak from either the High pressure supply hose are the low pressure return hose, one or more of the steering rack oil seals may be faulty or the pump may be leaking. so i would wash it all down and have a good look where the leak is coming from, if in doubt, get your mechanic to inspect and advise you.
Mark (mhpautos)
May 11, 2008 at 5:39 PM
