1991 Toyota Celica fuel system
211,524 MILES • 4 CYL • FWD • AUTOMATIC
STEALTH1979
My fuel pump was working for then it quit. I hit the bottom of the gas tank with my hand a couple times. It stated working again. Two days later I was driving and the car died on me. The part store showed me how to hook the fuel pump up to my battery to see if it was good or not. The pump kicked on like it was supposed to. My question is: What else could prevent the fuel pump from coming on and working?
Aug 20, 2008 at 5:08 AM
  • 75,988 POSTS
The circuit opening relay and the airflow meter- Try this open up the AFM and block open the flap-did it start up?
Aug 20, 2008 at 5:14 AM
STEALTH1979
[quote:4a5bf85e65="rasmataz"]The circuit opening relay and the airflow meter- Try this open up the AFM and block open the flap-did it start up?[/quote:4a5bf85e65]
I don't know where or what the afm is. Do you have a picture of it.
Aug 20, 2008 at 1:08 PM
  • 75,988 POSTS
Its attached to the aircleaner housing it has a wiring connector that has about 7 small wire to it-when it leaves the aircleaner. I recomemend you get a repair manual this one can be a nightmare to fix-
Do this find the diagnostic check connector and jumper Batt to Fp terminal and attempt to start
Aug 20, 2008 at 2:56 PM
