1991 Toyota Celica Dash Break Light Stays On
1991 TOYOTA CELICA
108,000 MILES • 4 CYL • FWD • AUTOMATIC
AZASAP
I have a Celica 2.2 with a continuous Brake Light warning on the dash. It was on when I purchased the car. The brake line was replaced but the light remained on. recently replaced the Timing Belt, thermostate and water pump. When I received the car back, the light was finally off. After a week or so it slowing flickered on and off until it is back on continuously. The brakes are good, fluid level full and float in reseviour woking. Any suggestions on how to make this kight turn off? I can;t use the Cruise Control due to htis failure as well. Any helo would be grat. Two different mechanics couldn't locate this prblem.
Jun 27, 2008 at 5:24 AM
Get the brake switch circuit checked out it also controls the shift interlock system.
Jun 27, 2008 at 6:00 AM
