1991 Toyota Celica catalytic converter
218,000 MILES • 4 CYL • FWD • MANUAL
LSNYDER1
I have a 1991 Toyota celica gt with a 2.2L 5a-fe engine. The catalytic converter on this model is very strange. It's actually called a manifold converter. It is attached directly to the exhaust manifold. On the manifold side the opening of the cat is about 3 inches in diameter, on the exhaust side it is only about 1 inch in diameter. Hypothetically, if i were to gut the cat and reattach it would I be susceptible to any problems from the open cavity in the cat? I have never seen a cat like this and am worried that a vortex might develop inside and cause the car to backfire or fry the valves.
Jan 22, 2008 at 5:40 AM
  • 75,988 POSTS
That is just the pre-heater Cat-its the one on the back that you have to worry about.
Jan 22, 2008 at 5:45 AM
LSNYDER1
I have taken the whole exhaust system apart. The other catalytic converter is fine. The manifold converter is the problem. I have a very hard time getting the car started and when i do I have to hold the gas pedal for the entire duration. I know this cat is the problem because when I do get the car started it starts glowing red hot. Also it will not pass air very well at all.
Jan 22, 2008 at 6:28 AM
  • 75,988 POSTS
Okay then If you're so sure its the manifold Cat-
Jan 22, 2008 at 6:34 AM
