1991 Toyota Celica
1991 TOYOTA CELICA
146,000 MILES • 4 CYL • FWD • AUTOMATIC
DYLAN F
when i am driving the transmission makes a noise like something is rubbing up against something. the noise seems to get louder when you make sweeping left turns. i put the car on jackstands and got under it, it seems like ware the axels go into the differental is loose. also when the car is in neutral and you rev the motor passed 2000rpm there is a very noticeable vibration. but it seems to go away when you put it in gear. and it also shifts into overdrive really early. thanks for looking it over.
Dec 24, 2007 at 4:24 PM
  • 31,937 POSTS
If there is a lot of lateral movement in the inner C.V. in the diff housing, you may have a problem with the bushes in the differential housing. I will investigate the diff housing in a few days time and re post what i feel is happening and what to do.
Mark (mhpautos)
Dec 25, 2007 at 5:44 AM
