HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Celica
Engine
Symptoms
Vacuum Leak
SPONSORED LINKS
Vacuum leak?
CHICO01
MEMBER
1991 TOYOTA CELICA
Hi I've been having problems with my car. It seems to shake when I accelerate it, like it wants to turn of.
what do you think the problem could be?
Monday, June 15th, 2009 AT 4:47 PM
MECHANIC
This sounds like a vacuum leak. However, we need to start with checking for codes.
Here is a guide that will help with getting OBD I codes:
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
This is the process on how to check for vacuum leaks. Please run through this info and let us know what you find.
Below you will find a chart on spark plug issues. We need to check this and pull the plugs and see if they are fouled. This could be a misfire or just worn spark plugs.
Please let us know what questions you have and what you find. Thanks
Image (Click to make bigger)
SPONSORED LINKS
Wednesday, July 14th, 2021 AT 8:16 PM
Please
login
or
register
to post a reply.
Related Engine Vacuum Leak Content
Vacuum Leak On 2000 Celica
Would A Vacuum Leak On A 2000 Celica Cause Engine Performance To Drop From 30mpg To Less Than 20?
Asked by
arl
2000
TOYOTA CELICA
VIDEO
Vacuum Leak Test and Repair
Instructional repair video
GUIDE
Vacuum Leak
An automotive engine heavily relies on a sealed vacuum system to help monitor and optimize the engine's performance, when this system fails and leaks emerge performance ...
1991 Toyota Celica Engine Shuts Off On Hot Days
Engine Performance Problem 1991 Toyota Celica 4 Cyl Automatic 158000 Miles On July 4th, 2008, While Driving On The Freeway My Efi...
Asked by
mrpeepers06145
1 IMAGE
1991
TOYOTA CELICA
1991 Toyota Celica Will Not Start
Electrical Problem 1991 Toyota Celica 90,000 Miles If Someone Could Help, I Would Appreciate It! Okay My Car Will Not Start, Or...
Asked by
mikey2007hustla
1991
TOYOTA CELICA
Mystery Oil Leak 1991 Toyota Celcia, Cannot See Where...
Had The Oil Change And Two Weeks Later Oil Was Almost Gone Needed To Add Oil
Asked by
lalalou
1 ANSWER
1991
TOYOTA CELICA
1991 Toyota Celica Won't Start
Electrical Problem 1991 Toyota Celica 4 Cyl Two Wheel Drive Manual Idk Miles My Car Will Not Turn Over. The Head Lights, Hazard...
Asked by
mikey2007hustla
1 ANSWER
1991
TOYOTA CELICA
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Hesitation
Online car repair manuals
