1991 Toyota Celica
JEWANBASDEO
  • 1991 TOYOTA CELICA
  • 4 CYL
  • FWD
  • 130,000 MILES
Hi my name is jewan and I have a problem with my car. I was driving and then I pull in to drop someone off and as the car come to a stop the engine shut off, I tried to start it but it never start again, everytime I start I got the cranking as if it gonna start but nothing happin the engine wount turn on. Also the fuel tank is full.
Wednesday, January 21st, 2009 AT 9:15 AM
You need to determine if its fuel or spark problem -do below
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
Wednesday, January 21st, 2009 AT 9:18 AM
