1990 Toyota Celica Timing Belt
295,000 MILES • 4 CYL • 2WD • MANUAL
ROBB1
I drove the car for about 10 miles, Everything was fine Shut the car off for about 30 minutes went to start the car ,I got the starter grinding with the flywheel then finally the motor cranked over but the timing belt is not turning. I understand that the timing belt probably sheered off the teeth of the belt but why did it lock up?
Jun 14, 2008 at 11:06 AM
KHLOW2008
  • 41,812 POSTS
Hi Robb1,
When the timing belt sheared off some teeth, some valves could have been fully open so when the pistons hits them, it will not turn.
Jun 23, 2008 at 5:46 AM
ROBB1
They say my engine 5S-FE is a non-interference engine. But when I got the timing belt off the teeth were ripped off the belt at the main crank gear.But the Belt seemed to be in good condition other than that.Tried to get the engine on TDC the top main cam gear will not make a complete revoloution around, it hits and will not turn. So Im thinking bent valves but they say my engine is non-interference
So what's going on?
Jul 10, 2008 at 5:31 AM
KHLOW2008
  • 41,812 POSTS
Hi Robb1,
Non interference is when belt broke, the valves are either fully or almost closed. Turning th camshaft with the piston at TDC would become an interference engine. When turning the camshafts some valves need to fully open so it will touch the piston top.
Turn pistons away from TDC then turn camshaft to desired position. After that only turn to TDC.
Jul 11, 2008 at 1:16 AM
ROBB1
I tried what you told me and I got the same result.
Jul 12, 2008 at 7:14 AM
KHLOW2008
  • 41,812 POSTS
Hi Robb1,
Did you turn the crankshaft away from TDC far enough? If not the pistons would still be very high.
Turn crankshaft 90 degrees away from TDC. Even if the valves are bent, you should be able to turn the camshaft if the pistons are not too high.
Jul 12, 2008 at 4:18 PM
