1990 Toyota Celica Locked Engine
CHEA2008
Engine problem
1990 Toyota Celica Engine Size unknown Wheel Drive Type unknown Automatic 230000 miles
My 1990 Toyota Celica has had its fair share of small problems since I bought it, but none have been so sudden, or detrimental, as this current problem that I am having. While driving on the highway, my car stalled and the engine died. When this happened, all I could was guide the car into the emergency lane. I tried to restart it while iin the emergency lane, but it would not turn over. Initially, i thought that my alternator came loose because the charge level of my car was not within the proper bracket to run. But after the tow truck came and gave me a jump, I found that hypothesis to be incorrect because the car ran only as long as the tow truckers batter charger was attached; once that was removed, the car died again. My car was towed to a mechanics shop where they tried to start the engine and told me that "it would not turn over. The engine was locked". I do not know what that means or how I can fix it. Hopefully, you all can help me with this unfortunate circumstance. Thank you for your time.
Feb 7, 2008 at 4:42 AM
  • 75,988 POSTS
While on the move-if its a broken timing-I dont think the towman will be able to start it with his batteries-
Try getting the alternator and battery checked-out
Feb 7, 2008 at 4:52 AM
