1990 Toyota Celica Fuel pump not getting power
200,000 MILES • 4 CYL • FWD • MANUAL
HAISLOP
does car have fuel shut off switch and where is it?
or what else could cause this?
Jun 12, 2010 at 4:04 PM
  • 75,988 POSTS
Hi haislop, Welcome to 2carpros and TY for the donation
What powers the fuel pump is the circuit opening relay when the airflow meter grounds the relay.
Try this block open the flap in the airflow meter and attempt to start it- or you can jumper the Fp to batt terminal in the check connector and see what happens
Jun 12, 2010 at 6:15 PM
  • 31,937 POSTS
You can also check the fuel pump relay relay block R/H/side of the radiator.
Mark (mhpautos)
Jun 12, 2010 at 6:31 PM
