Engine Mechanical problem
1990 Toyota Celica 4 cyl Front Wheel Drive Manual
I started working on the engine of my vehicle because there was a leak under the timing belt cover. I took apart the water pump pulley,timing belt, oil pump body and body cover. I replaced all gaskets. While installing everything back together and starting up the car I noticed that the engine wasn't running smooth. It sounded like a skipping sound, plus from the exhaust the was white smoke. When I looked at the spark plug there was some oil,possibly water mixed in as well. Please could anyone help me with this situation. Another thing i have to ask,say if i didn't put the timing belt on exactly as I took it off, could that also be the situation?
Jun 1, 2010 at 10:03 PM
