1990 Toyota Celica EFI
190,000 MILES • 4 CYL • FWD • MANUAL
MARTHA03
I REPLACED THE EFI FUSE.STARTED RIGHT UP AND RAN FINE.THEN WOULD NOT START THE NEXT TIME.SO I REPLACED THE EFI RELAY.STARTED RAN FINE.THEN WOULD NOT RESTART.SO I TRIED THE EFI RELAY AGAIN.WOULD NOT START. BEFORE ALL OF THIS .I HAD LEFT THE OIL CAP OFF AND OIL CAME OUT UNDERTHE HOOD AND CAN BACK DOWN ON THE RT. SIDE OF THE ENG.(THAT WOULD BE THE FRONT OF THE ENG).THE ONLY THING THERE IS THE FIRST FUEL INJECTOR.
I SEEM TO THINK IT IS OK BECAUSE IT RAN SO WELL.HELP.
Jul 12, 2008 at 4:59 AM
KHLOW2008
  • 41,812 POSTS
hi martha03,
I can't make head or tail of your explanation, just that I know your car cannot start and you have replaced the fuse and EFI relay.
Did you check for sparks while cranking?
Jul 13, 2008 at 4:15 AM
