1990 celica gt idle surging between 1500 and 2000
SWITCHCRAFT
  • 5 POSTS
90 celica gt automatic 2.2 engine
idles up to 2000 then back down to about 1500 then back again
i have 2 videos i made of it
so far i.............
cleaned the egr valve(was sticking and full of carbon)
plugs have some carbon on them so i took them out and clened them too.....
they are bosch platinum plugs
a little history about it i bought the car with some rusted fuel lines in the winter i let it sit until this summer,fixed the fuel lines,it didn't have an air filter so i got one.....the idle was this way ever since i bought it........
check engine light was on i tested it flashed a code for the map sensor.....bought one used put it in now i get NO TROUBLE CODES
and it still idles funny......put it in drive or reverse it runs fine.......
here's the 2 videos i made........
this first vid just shows how bad it idles
http://video.tinypic.com/player.php?v=2m488b9
this vid shows how it is in drive and reverse
http://video.tinypic.com/player.php?v=48yngd4
this last vid shows how it runs after i pull the vaccuum line off of the intake....it's the line that comes from the dashpot
http://video.tinypic.com/player.php?v=47b10zq
Sep 29, 2006 at 12:50 AM
SWITCHCRAFT
  • 5 POSTS
does anybody know??? :(
Oct 5, 2006 at 9:02 AM
  • 75,988 POSTS
Clean out the throttle body and the IACV and check the TPS
Oct 6, 2006 at 9:36 PM
SWITCHCRAFT
  • 5 POSTS
right now i took off the intake manifold , fuel rail, iac motor, and throttle body
the manifold is being boiled out at a local shop for only $20
when i get everything put back together and cleaned i will post the results....
Oct 9, 2006 at 2:44 AM
