HOW IS THE MAIN CABLE FROM THE BATTERY TO THE STARTER HOOKED UP? IS A CLIP OR IS IT A NUT & BOLT?
Mar 13, 2009 at 8:28 AM
✓Experienced Mechanic
HI there,
This is attached to the starter with a nut, there is a mounted threaded bolt fixed into the starter and the cable end fits over this and is secured with a nut, there is (should be) a plastic cover over this stud to protect it from accidental shorting.
