When I start the engine up from a cold start and it gets to running temperature it will often stall. After I let it set for a few minutes it will start right up. This does not always happen. It seems to happen more when the weather is cooler. I did take it the mechanic and they did an emssions cleaning and replaced the fuel filter. The car seems to run a litte better but the problem still exists. I've been told it might be a temperature sensor in the fuel system. Any ideas?
Mar 26, 2008 at 11:39 AM
