1987 Toyota Celica tail lights
100,000 MILES • 4 CYL • 2WD • MANUAL
11BRAVO6888
My brake lights, head lights, turn signals, and hazards work but not my regular tail lights.. Checked the fuses and bulbs and thats not what it was.. What could it be?
Dec 12, 2009 at 11:59 AM
POZOBYT
  • 37 POSTS
You probably have a wire loose somewhere, I had problem like that after I got rear ended, it pinched the wires in my trunk so that everything worked but the tail lights, even though the regular break lights worked.
So check all of your wiring for your tail lights and make sure nothing is frayed or grounding out.
Dec 13, 2009 at 1:43 PM
