1987 Toyota Celica high idle
TOMARR
Engine problem
1987 Toyota Celica V4 Front Wheel Drive Manual 165000 miles
engine idles 2200rpms even when warmed up. no vac leaks air leaks starts and runs good. could it be o2 sensor or bad mass air flo?
Dec 2, 2007 at 6:07 AM
  • 31,937 POSTS
Hi there,
Check for any set fault codes, Check A/C idle up VSV valve is not open and check idle air by pass screw is not leaking.
Mark (mhpautos) :D
Dec 6, 2007 at 10:00 AM
