1987 Toyota Celica head gasket issues
1987 TOYOTA CELICA
BENGALARI
Engine Mechanical problem
1987 Toyota Celica 4 cyl Front Wheel Drive Automatic
out of curiousity, is it possible to remove the head without pulling the engine out of the vehicle...
Sep 3, 2009 at 1:09 PM
Its the hard way to go but it can be done the head is the upper end of the engine.
Sep 3, 2009 at 6:25 PM
BENGALARI
I actually have two different cars in the garage at the moment, both blown gaskets, an 89 Camry and an 87 Celica... same engine, just curious bout the work because i have indeed run into some difficulties, thank you for your help, i will definitely keep this site in mind when i run into issues.
:D
Sep 3, 2009 at 6:40 PM
